Message |
After thinking about it, I will plug the exhaust valve cover ports and run hose from the intake valve cover ports to the pcv ports in the plenum. Then I will install the catch can in-line. What do you think? Is there any draw-back to removing the actual pcv valves if running a catch can? I've read that pcv valves can act as flame arrestors in case of a backfire... Thanks
